KIA BESTA 2.7 spends a lot of water and heats up
14 years 2 months before #26437 by manual-mecanica
Manual-mechanics' response on the topic Re: Kia Besta 2.7 uses a lot of water and overheats
I have a feeling they didn't resurface the cylinder head, or worse, they might not have tightened the cylinder head bolts properly. The same thing happened to me recently with a '96 Jetta/Vento/Bora, 2.0 engine. They tightened the cylinder head bolts incorrectly (because a bolt broke), and it was burning through coolant. It could be that your car wasn't torqued correctly, or perhaps they didn't do the resurfacing job at all. You should pay attention to that.
14 years 2 months before #26459 by manual-mecanica
The issue is tricky. If the cylinder head is okay and everything else is the same, the cylinder block might be warped. Try pouring in some Cella Block or water-soluble glass to see if it cuts the seal. Something similar happened to me in a Fiat, and I did that, and it's been running well ever since. It's super cheap; you have nothing to lose.
14 years 2 months before #26470 by manual-mecanica
Hey, we think of everything except a clogged radiator! Why don't you have it flushed? When I repair a car for overheating, I change the water pump, thermostat, check the hoses, and flush the radiator. Check yours; it might be clogged. Also, check that the fans are turning on, because we never actually ask about that. Check it and post your results.
14 years 2 months before #26479 by manual-mecanica
Yakita, one question... of everything you checked, did you verify that the coolant is circulating correctly? It might be the water pump...
14 years 2 months before #26709 by manual-mecanica
Friends, let me tell you what's happening to me now... It's not overheating, but the water is leaking from the auxiliary tank... Is this normal, and does it refill later? Please reply soon...
I need your help, friends...
