KIA BESTA 2.7 spends a lot of water and heats up
14 years 3 weeks before #26778 by manual-mecanica
Friend:
Thank you very much for your tips ... It is a great support for my Susu Act advice say many things but nobody is worthy ... you are worth gold ..
14 years 3 weeks before #26779 by manual-mecanica
Another mechanic told me that it was normal to spend water at this time is true ??????????
prefers to spend water instead of getting the thermostate.
14 years 3 weeks before #26781 by manual-mecanica
sometimes passes the compression depends on where the crack is
14 years 3 weeks before - 14 years 3 weeks before #26783 by manual-mecanica
The only problem that the KIA had at 6 years of having it 0km, was that the lid was punctured between the two closes of valves, the solution was to take the lid to a rectified engines workshop and they made hydraulic test and detected where the loss was. The lid was not corroid because he used a good refrigerant but it was the only problem in 10 years. The lid because the concavity of the cylinder that lost is like running through the water and combustion hydrogen.
Greetings Daniel
Bs As Argentina
Latest edition: 14 years 3 weeks earlier by .
14 years 3 weeks before #26789 by manual-mecanica
Hello "jl" thanks for the discomfort good drawing, let's see where he says a closed lid is to the radiator, where the red arrows are to the engine. Where he says water current, where he is? vehicles with 2 thermostats and this is the time that I do not understand what they serve 2 if with 1 enough ... I reiterate my thanks for your kindness
