Fiat Siena Diesel 1997 Buijias warming
17 years 4 months before #3915 by manual-mecanica
Manual-Mecanica Response on the Re: Fiat Siena Diesel 1997 Buijias warming
That black box that you say is the feverlot switchboard if it turns off the light at 5 sec and the current continues to reach the heater there is no problem draws the four heater and check them that sometimes lasts the light a little when a burnt heater has.- Greetings Alf.-
17 years 4 months before #3920 by manual-mecanica
Hello alf, you are sure that this black box behind the board of the car that is very hiding and difficult to remove is the central of the heating, there are two boxes one of sheet and one of plastic, the current as you say if you reach the spark plugs in the 13 seconds.
And it is true the signal of the board that lasts 5 seconds and turns off. I must think that in the plastic box are the replacements that I must change.
The tempisor box that is next to the fuel filter is the one that Calinta Las Bujias.
As a comment, it seemed very rare that you have to dismantle half a car to change one or the four -mantees that are located behind the dashboard of the driving steering wheel,
I will thank you for guides me a little more.
Marble greetings
17 years 4 months before #3937 by manual-mecanica
Hello Marmol, not the box of the heater is the one next to the diesel filter and there are several types of boxes there is a white gray and one black each has a light on and according to what type of heater use the car, that box that you tell me can be some control switchboard or the immobilizer switchboard give me all the data of the car and dode this exactly this black box you say.
17 years 4 months before #3941 by manual-mecanica
First of all, thank you for your Alfred attention, if I knew that the box next to the diesel filter is the one that regulates the heating time of the spark plugs is a black box which I have opened and has an electronic circuit and a bovine that functions as electriman and the ear feels the start of the beginning and completion of the time that is 14 seconds, which is not the one who gives the signal to the indicator of the board (signal of the luminous resistance (signal
What I am thinking is that Elemnto heats the bone spark plugs that happens to you electric current? The failure may be given that maybe it is not necessary to heat the spark plugs the 13 seconds and if what the board sends the 5 seconds for the consequent I can have an injector pump failure.
The black box or the two that finds are taking the board and if you look to the background you see the velocimetro gut and there is a sheet of sheet metal with the two very strong fastened boxes with a metal structure such as abrasaderas.
The car's model is Fiat Siena Turbo Diesel year 1997, frabicated in agentina with Utopartes from Brazil, Italy and Argentina. I have the vehicle since I left the factory bone from zero kilometer, I know it by heart, thanks Marcelo.
17 years 4 months before #3945 by manual-mecanica
The bulb that commands the preheating, is located near the thermostat, if I am not mistaken is blue and is part of the back. Unplugo and fix if the light witnesses the time (it will take time to turn off; the spark plug and the witness turn off almost at the same time). The preheating time of the spark plugs will always be the same (those 13 seconds you say), what will vary is the time of the witness ... surely you throw black smoke so it takes you to turn on.
