Pick Up engine Pass oil to the radiator
13 years 8 months before #32188 by manual-mecanica
Manual-Mecanica response on the Re: Pick Up Motor Pass oil to the radiator
Ok, I thank you for your comments and support, now referring to repair, if it is a very small fissure, 1st. How do I find it? and 2nd, like the seal, can welding be applied? or if you have to change the monoblock?
13 years 8 months before #32197 by manual-mecanica
It is very difficult for it to be the monoblock I do not think that your problem is, but if you kill it, you send it to do a hydraulic test and welder the failure as far as possible obio, but it takes the first man taken out man who is the most normal thing that happens. Or throw soluble glass or a sellable to see what happens you do not
13 years 8 months before #32263 by manual-mecanica
I agree with the corduroy that says that it is the cuisine's packaging, but I add that you must revive the plan of the cylinder head in case you should do flat, eye this is if it is synchronous, of being automatic go to the serpentin of the box to see. and check the oil in the carter.
13 years 8 months before #32264 by manual-mecanica
Hello, to the mechanic who took it, I take out the cylinder cover to tell you that the Board was not the problem? Because without taking the lid you will never be 100% sure that is not, it does not necessarily have to pass water to the oil and oil to the water to say that the problem is the problem. You can burn part of the joint and only for water to the oil or the revenge, as you can also burn the metal ring of the joint and pass the water to the cylinders. I would recommend you take out the lid if you did not start there. And well if that is not the problem you will have to continue disarming until you find it
