Ignition problems of an X Trail 2008
13 years 9 months before #30931 by manual-mecanica
Manual-Mecanica Response on the Re: Igniring Problems of an X Trail 2008
partner already put the compression tester? This morning he gave me a lot of work to start an Opel because the hydraulic divers "air" causing the admission valves not to close completely and there would be no compression; I had to disassemble all hydraulics to download the oil and that could close the valves
13 years 9 months before #30972 by manual-mecanica
Hello brother I had a similar problem with a 2004 XTail Try this I put a jet of gasoline in the admission if it does not turn on it is a compression problem if you turn on it is the problem of injectors please respond as it went. Greetings from Honduras
