Ignition problems of an X Trail 2008
13 years 9 months before #30789 by manual-mecanica
Manual-Mecanica Response on the Re: Igniring Problems of an X Trail 2008
If thanks already, everything you comment and connected the SCAner OBD2 and an error code that is P1777 that means Step Motor or request for delay of ignition of the fault circuit and really do not know what it means thanks for your help friend
13 years 9 months before #30804 by manual-mecanica
The ignition comes with a hose connected to the empty? There were about R19 that came with that type of ignition and failed when their diaphragm was punctured
13 years 9 months before #30816 by manual-mecanica
It is the engine that I am sending you the draft
13 years 9 months before #30820 by manual-mecanica
If you put the Scaner you must look at the start that at least the RPM rise from 250-500 rpm this will indicate if when changing the chain you do not run a point and if the chain is well synchronized, and it also tells you if the CMP and CKP sensors are working.
13 years 9 months before #30822 by manual-mecanica
There I send you the p 1777 code that you indicate, I ask you if you notified if you received them, luck
