Chevrolett Aveo Codes 2004 (P0351-P0353)
14 years 1 day before #27743 by manual-mecanica
Manual-Mecanica Response on the Re: Codes Chevrolett Aveo 2004 (P0351-P0353)
I had a problem equal to yours in Chevrolet Aveo but 2011, try all coil, cables, spark plugs, injectors, injection pulse, cylinders and nothing, I had it two weeks and entered and took it out of the workshop and removed only from one day to another never failure. But check everything that I check as you are doing as a track I say
14 years 11 hours before #27792 by manual-mecanica
Check everything to change spark plugs and cables and nothing is still compreated in the range allowed any more suggestion? according to the codes that devote to review apart from the coil?
14 years 11 hours before #27793 by manual-mecanica
What failure presents the vehicle
14 years 10 hours before #27800 by manual-mecanica
The failure it presents is like a cylinder does not work as when a spark plug is damaged, but they are new and proven.
14 years 10 hours before #27801 by manual-mecanica
You have not tried another coil game
