Chevrolett Aveo Codes 2004 (P0351-P0353)
13 years 11 months before #27919 by manual-mecanica
Manual-Mecanica Response on the Re: Codes Chevrolett Aveo 2004 (P0351-P0353)
OBDII CODE LIST> P0351
P0351
P0351 - Ignition coil 'A' Primary/Secondary Circuit Malfunction
1
0 Comments | Add Comment
Symptoms
- Engine Light On (OR SERVICE SOON WARNING LIGHT)
- LACK/LOSS OF POWER
ENGINE MAY BE HART TO START -
ENGINE HESITATION
- ROUGH ENI
LOB Electrical Connection - Faulty Ignion Coil Primary/Secondary
- Faulty Engine Control Module (ECM)
When is the code detected?
The Fails When the Engine Control Module (ECM) does notice Valid Pulse Signal from the ignition coil.
P0351 Description
The Ignition Signal From The Engine Control Module (Ecm) is feeling by the power transistor. The Power Transistor Turns On and off the ignition coil primary circuit. This on/off operation induces the proper high voltage in the coil secondary circuit.
13 years 11 months before #27920 by manual-mecanica
Enter register
Q & A
TSB
OBDII Articles
OBDII CODES
LIST OF CODES OBDII> P0353
P0353
P0353 - COBINA 'C' MALL FUND OF THE PRIMARY / SECONDARY CIRCUIT
1
0 COMMENTS | Add comment
The symptoms
- Light motor (or motor service light soon warning)
- Missing / loss of energy
- engine can be more difficult to start
- engine hesitation
Gruto -idle engine
between
possible
causes Primary / secondary ignition coil
harness of the control module engine (ECM)
when the code is detected?
The test fails when the motor control module (ECM) does not receive a valid pulse signal of the ignition coil.
P0353 DESCRIPTION
The ignition signal of the motor control module (ECM) is sent and amplified by the power transistor. The active power transistor and the circuit of the primary coil of ignition is deactivated. This ON / OFF operation induces the high voltage in the secondary coil circuit.
13 years 11 months before #27931 by manual-mecanica
This type of coils is very common that Fayen may be that the problem is that it is too weakened the spark and the best scheme does not buy one in print because a client of mine bought a there and then I claim because it lasted only 15 days after verifying that this coil was bad I made it buy one in Didea at the end for wanting to scare a little more expensive greetings to you also from you also from the savior
13 years 11 months before #28099 by manual-mecanica
Hello problem solved, to despise that the coil that had generava siera amount of spark in the four terminals was isufisiente for a good spark. And for generating spark, he doubts whether to change it or not. Thank you all for taking your time in this little problem.
P0351 and P03853 CODE TWO OCTIONS Review the connection from the coil to the PC Verify that there are no cut or spent lines (corroids). Change the coil This was the one that worked for me code already off with 5 days of testing from this publication. Thanks and greetings.
