Does not turn on diesel engine 1.9 405 97
14 years 2 weeks before #27015 by manual-mecanica
Manual-Mecanica Response On the Re: Does not turn on Diesel Engine 1.9 405 97
You tried to throw it to start sometimes you throw it a little and leave immediately, and the other Czech that comes to the ramp of incondent spark plugs, one thing is that this new other qdistinto that works.
14 years 2 weeks before #27017 by manual-mecanica
Be careful with what they say about pushing, you can create a tension peak, and as a minimum fuses, but it could go to more (not everything has fuse)
that I do not boot for a simple warm is quite strange, it could have made some crack (if the warm was a beast) but the engine would do something with the rest of the pistons.
If fuel arrives, and the rest is fine, I would start looking at the injection pump.
I think yours is not synchronized, so see preparing the pocket (if applicable).
Check that the fuel pump works, which reaches tension to the injectors, the heater (care in doing so).
Good luck, having such is doing.;)
14 years 2 weeks before #27024 by manual-mecanica
Sometimes when the cylinder heads are cup, the cable is the stop electrovalve. Check that they arrive 12 v. Salu2
14 years 1 week before - 14 years 1 week before #27446 by manual-mecanica
Hello everyone again, I have proven everything that they advised me on the subject, there is current in the preheating spark plugs, diesel comes to the injectors have compression the cylinders, the injection pump is Bosch and new, the set -up of the distribution is fine, it is aspirated, not turbo, the battery is new for diesel, but it does not start, it does not start, it does not start, it does not start, it does not start, it does not start, Turn on, some more facts that can help me thanks to everyone, for your patience, greetings and I will thank you for any help,
Last edition: 14 years 1 week before by .
14 years 1 week before #27449 by manual-mecanica
Hi, here there is something strange without a doubt. Look if no key of camshaft, injection and crankshaft pump gear is cut. You can also try to give Arranke are the escape pipe and without the multiple of admission. I hope you find you and problem and as a thing mattenenos aware, good luck
