Atmospheric pressure
14 years 2 months before #25090 by manual-mecanica
Atmospheric pressure published by Manual-Mecanica
Hello ... what percentage affects the atmospheric pressure in relation to the height, a turbo engine.
14 years 2 months before #25127 by manual-mecanica
Manual-Mecanica Response on the Re: Atmospheric Pressure
to an engine with turbo almost nothing, to the aimless much much,
14 years 2 months before #25138 by manual-mecanica
The atmospheric pressure influences the compression of an engine and in what percentage ..
14 years 2 months before - 14 years 2 months before #25140 by manual-mecanica
The compression measure can vary according to the engine RPM, so the compression measurement must be taken at the engine starting speed since the volumetric yield decreases to the highest rpm of the engine since the higher RPM the filling time of the cylinder is lower and the atmospheric pressure enters into play, then it means that at the lowest atmospheric pressure the filling time is smaller Atmospheric
In an engine on fed, the atmospheric pressure is almost not affected, since the filling pressure is much higher than the atmospheric pressure, but if in the height the percentage of oxygen in the air is lower and that affects a stoichiometric mescla
Latest edition: 14 years 2 months before by .
14 years 2 months before #25143 by manual-mecanica
if I measure the compression of an engine at sea level and 4200 meters
