Renaul Megane II does not turn on. If it starts
14 years 2 months before #24557 by manual-mecanica
Friend Renault does not handle camshaft sensor or CMP either in the case of the Magane II TPS He has app on the aselerator pedal that complies with the same function of the TPS. On the acceleration body they have as a butterfly Motorisada Tac or etc.
14 years 2 months before #24752 by manual-mecanica
Friend "Daninovato" I would like you to help me identifying the piece of which you have always spoken to me and if you completely disassembled it, I explain in the attached file there are two pieces but the first one that seems to be of which you speak to me identified with the No. 120 is sealed and I do not know if it can be disarmed. The second is called the accelerator potentiometer and I don't know if it is which you mean.
Thanks in advance
