Renaul Megane II does not turn on. If it starts
14 years 4 months before #24512 by manual-mecanica
Okay friends, I fixed the fuse box, the car starts but it still has an idle problem; when I press the accelerator it's like it's choking. I'm going to check the TAC or ETC as CRAZY and DANINOVATO recommended. I'll let you know how it goes.
14 years 4 months before #24514 by manual-mecanica
Check the following components related to idling:
*CKP crankshaft sensor. Indicates that the engine is running. Also check the camshaft position sensor.
*IAC idle air control valve. This controls the airflow for idling.
*TPS throttle position sensor. This indicates the desired acceleration. It has a contact that signals whether the driver is accelerating the engine or not.
*MAP absolute pressure sensor. Indicates altitude above sea level.
You can check these with a multimeter.
14 years 4 months before #24515 by manual-mecanica
I think you should first check your fuel pressure. The hesitation you mention when accelerating could be due to low fuel pressure
14 years 4 months before #24522 by manual-mecanica
Don't doubt it, that symptom of choking is exactly what happened to me; it's a matter of cleaning the CT scanner. I'm 99% sure that's it
14 years 4 months before #24526 by manual-mecanica
What I can recommend is that you test the spark plugs for spark, to rule out the crankshaft sensor. It could also be that the immobilizer (anti-theft system) has been reprogrammed. Check the dashboard to see if you see any abnormal indicators, or pour a little bit of gasoline or
fuel on it to see if it at least starts momentarily.
