Problems with a Ford Fiesta
14 years 6 months before #21370 by manual-mecanica
Manual-Mecanica Answer on the Re: Problems with a Ford Fiesta
If the fan turns on, I'm sorry when the temperature does not get up yesterday, the city and has not heated almost anything caught in the radiator fan and under the temperature he kept 80 ° more or less but the other day he came x the night of another town k was 30 km The water heats up and the thermal change is changing and it still can be the water pump you tell me what I can do step by step thanks
14 years 6 months before #21375 by manual-mecanica
The fine hose is the one that has you placing you in front of the water storage on your right hand that hose when it is cold then put it in a resipient and there will be observed if the pump is working to come out water if need to accelerate by car
14 years 6 months before #21378 by manual-mecanica
The water pump is located bass of the water resipient heart you will see a pulley that contain three 8mm screws first loos Pulley you will get three more than 8 millimeters you take out those three tonillos and then read a slight blow and the pump comes out there you will observe if this game or is missing after the blade has to carry as thickness of a cylinder that she wears she sticks from the blade that cylidro is plastic and of the same color check inside where she goes if she does not have a residual party of the pump I hope you help you my help
14 years 6 months before #21388 by manual-mecanica
If you say that yesterday it did not warm up, you can have a problem with the electrventillator that sometimes does not start, it is so you have to take it to someone who knows the subject will greatly be an automotive electrician obviously or a mechanic that can review the fan system (why not everyone gets into the electric part) sees telling how you are ... greetings.
14 years 6 months before #21393 by manual-mecanica
Czech if your fan enters if you don't enter Czech feeds and if your temperature bulb are good, I hope it helps you.
