Problems with a Ford Fiesta
14 years 3 months before - 14 years 3 months before #21333 by manual-mecanica
Problems with an Ford party published by Manual-Mecanica
Good to see who can give me a hand I have a 2006 Ford Fiesta and began to heat 120 ° and change the thermostat and it remains the same in addition the water evaporates through the lid I no longer know that it can be someone to help me thanks
Latest edition: 14 years 3 months before by .
14 years 3 months before #21341 by manual-mecanica
Manual-Mecanica Answer on the Re: Problems with a Ford Fiesta
Friend ..... It can be the water pump .....
14 years 3 months before #21342 by manual-mecanica
Hello ... mechanical or automatic ??? What type of fan do you use ??? Uncover the cold radiator or the deposit if the radiator were without a lid and see the behavior of the refrigerant ... if there are bubbles or the water goes out to press where you will have to take out the cylinder head ... From there you accounts as it went ...
14 years 3 months before #21346 by manual-mecanica
Necanico The radiator does not have a lid is the fan but bubbles does not make it evaporates when the water is heated out through the dome lid is in Edl Agua disposite
14 years 3 months before #21347 by manual-mecanica
If as I realize you can tell me a guidelines and I am a girl thanks
