Rare sound
18 years 2 months before #1632 by manual-mecanica
Manual-Mecanica Answer on the Re: Rare Sound
Hello, I have a question, it turns out that I do not want to buy the pieces that this is sure that I need the roller bulls and soften with a kid I said the one has a complete game but of the 1.8td engine that mint the peugeot 405 saveis if they were worth for the 1.9d engine of the zx like that it would disassemble without having to wait a time to bring the pieces and if they do It already rode one more thing this morning and had to make the car for an emergence and noticed that about 2000 laps it seemed to have a raising cascavel sounding
18 years 2 months before #1643 by manual-mecanica
Hello everyone. If you have not yet disassembled the connecting rod caps, try before seeing if the noise for when you step on the clutch. A 205D that carries that same engine-change I did the same and what it sounded was the primary of change.
When the oil was heated the slack that had a little noise in the primary that was only heard when the car was stopped and the engine at idle.
When you have done a few kilometers, with the engine torn off, step on the clutch and put a speed to stop the movement the gearbox, if you stop hearing the happy noise you already know where to start looking.
18 years 2 months before #1654 by manual-mecanica
Thank you `for the Idea Jmruiz
but it is not the healing that you mention since I am tested and the sound is heard stronger in the part of the engine of the engine bone by the lower carter I only have time and I can put hand in it I am aviego to subjects and ideas and grcias to all
18 years 2 months before #1656 by manual-mecanica
Hello everyone, finally and the engine and do not seem that they are bad that they have very little wear only three decimas of millimeter or so and one that has a very very small scratch the crankshaft is intact and those of bench only and looked at those of the second and third
apol The oil pump to the height of the block and seen that it does not have any type of joint or something that
swam I fail) both in the same stretch or bannly
thanks
18 years 2 months before #1657 by manual-mecanica
Well, I already have the
replace
