Problems with EGR valve
16 years 1 month before #9376 by manual-mecanica
Manual-Mecanica Answer on the Re: Problems with EGR Valve
Hello, look personally I do not agree to cancel it by emptiness or electronic since it is put on ayi to control the recirculation of the exhaust gases (NOX), if it is electronic and you manage to cancel it you can solve the problem but temporarily and this will no longer bother you, but over time you will have problems of, temperature, consumption, minimal march Gases will affect you, this will only give you headaches and affect your pocket, what I advise you is whether they already cleaned it and the problem is not solved and you are sure that it is the EGR to change it for a new one and leave everything as it should be originally.
greetings.
16 years 1 month before #9411 by manual-mecanica
Hello, how are you ??? I personally that when I know an engine I am to eliminate the EGR since it is designed for the environment, and what produces in an engine is a greater wear here in my country the customer wants the car to last longer, and even more so when it recently adjusts its engine. greetings
16 years 1 month before #9417 by manual-mecanica
Hello, all the opinions are respectable, but at least in my country there are environmental regulations that do not allow any part of the environmental package offered by vehicle builders, on the other hand I do not think that when eliminating the EGR the engine works better or has better benefits, otherwise as mentioned above there are more serious problems and this fulfills a very important function both for the engine and for the environment, because for something the builders spend a lot of money in Designers, these things do not put them there because yes, anyway respect all opinions, but we think of our children and those who come within a few years also deserve a clean environment.
balances
16 years 1 month before #9426 by manual-mecanica
You have no idea what you say. The open EGR valve only serves for annulled problems will not give you any more.
16 years 1 month before #9427 by manual-mecanica
Gentlemen I remind you that here we are here to help us and not to fight and everyone can contribute what is positive to me by Eleplo The EGR has created various problems from an irregular minimum, as lack of power, and as a pull in the car at 2000 laps and the house has sent me order to cancel it in Mitsubishi Motor 2.5 TD and stop counting, in the Opel the cleaning of the valve is recommended. 6 months .-
