Isuzu 3.0 motor failure
11 years 8 months before #45374 by manual-mecanica
Manual-Mecanica response on the topic Motor Isuzu 3.0
Although the engine goes well, you should check the pump draft in case the workshop is not left at its point (you say it moved it) it is not known if it left it again at its point (in the manual it describes this).
11 years 8 months before #45416 by manual-mecanica
You know, today I was thinking that, if this change the progress, in theory it would have to change it, because otherwise I spent more, or will not go so fine, I do not know, in addition it has been turned on some times for a brief space of time the check Engine, to see if I find that of the draft and if m can fix it in any other workshop, there I will not XD
11 years 8 months before #45418 by manual-mecanica
Hello again! , on page. 6-C 21 of the manual comes to you, it already seemed to me that I would have corrected it ... That is why I told you, it is "out of point", the draft, miratelo is simple, I told you that even the screws of the sliding bomb are loose ... do not walk like this without checking the draft point. Greetings!!!
11 years 8 months before #45419 by manual-mecanica
Surely you will have advanced a tooth, at most two, you will have to delay until the brands coincide (with draft crankshaft with rod or screw of m6x30mm) page 6c-21 and 6c-22
