Isuzu 3.0 motor failure
11 years 10 months before - 11 years 10 months before #45350 by manual-mecanica
Manual-Mecanica response on the topic Motor Isuzu 3.0
First of all I would like to thank you, because with the exposed things of each other, I think we are reaching what is the subject in question, my thought is similar, it is not a mechanical problem, the screw is well as Ismael says, or seleneoid or even some of the electronic plate, my determination is more or less the next, go to collect today the crane and put the work to work, fix it to the Situations, and with what you contribute aki, surely that it can be solved, it may take a day or 3 weeks, but total I lost 2 months for another week, it will not be deadly of necessity, for sure if I fix it, I will put the solution in detail in case the same time, the same will happen again, again thank you very much
by the way the code is p0216
Last edition: 11 years 10 months before by .
11 years 10 months before #45352 by manual-mecanica
Hello, if you decarly decariate the PDF Service Manual (it is free, 17.6 MB) on the page, 190 you tell you this failure 216, in the 203, you can see the screw, purge the circuit so that there is no air and the pump is well prieiled, if barley problems persists, you would have to check the loafer of the deposit (to discard). This manual is very useful to see the operation (I recommend it) greetings and luck !!!!
11 years 10 months before #45353 by manual-mecanica
And first of all, check the pump draft in the distribution (in case they have "moved" to correct it) pag. 6-C 21 of the Service Manual describes the draft points (it is simple)
11 years 10 months before #45354 by manual-mecanica
If this is the design-egine.ca/vehicle/
11 years 10 months before #45355 by manual-mecanica
It is section 6 -e Pag 190, the screw is below. In the 203 (on the left margin you have a vertical list, you choose there the failure 216, you get direct the page 190 begins the theme of failure 216 there until 203)
