Isuzu 3.0 motor failure
11 years 9 months before #45309 by manual-mecanica
Manual-Mecanica response on the topic Motor Isuzu 3.0
This is extracted from an Isuzu service manual (I do not find the link ..) is the screw that is housed on the right (marked the yellow tube), says to replace it
11 years 9 months before #45313 by manual-mecanica
That bomb is very similar to mine, because apparently that also looked at it, (eye that says the mechanic), tomorrow will choose to look at some electrical issue, since the failure, it gives only when the crane is heated, I told him that he would look at the plaque, I tell me that it is new, he made a manual advance and stopped having smoke, something we move forward, he gives pull What it is, and the problem is that in Tenerife is only that specialist in those arrangements, if it is true that he is turning him and turns to solve it, to see if tomorrow there is more luck
11 years 9 months before #45315 by manual-mecanica
If you say that it is when the water heats, already commenting on the water temperature sensor and the pump avace, it measures its resistance between the two poles, it must measure at 20º = 2370 OHMS at 80º = 290 ohms to be bad, it would give code 115, this can be verified anywhere, if you have doubts in the obstructed screw (Take a gauze filter inside) they may not have changed it ...
11 years 9 months before #45316 by manual-mecanica
And if I moved the progress, it must think if it will not be badly mounted, that you check that the piñon marks coincide with the housing, it does not go to be ... remember that they tell you of 4700 "M," by a bomb and if then it is from the screw ... You are not going to find out ... walk "to the guay" that you already have enough with the crash. Luck!!!
11 years 9 months before #45334 by manual-mecanica
... hello, Minge says, neither bomb nor injectors since the problem would be presented from the beginning with the contestant problem. In this case it is when taking the work temperature the engine. You do not let it clear if it is smoke or steam what you see for the escape to make one diagnosis but possibly a problem in the Board of Curse ... greetings
