Putting with Hyundai Santamo lamp
12 years 6 months before #42108 by manual-mecanica
Manual-Mecanica Response on the topic tuning with Hyundai Santamo lamp
Hi Ar.Casilla, I am from Argentina and apparently the problem is that there is a bench retain that drips oil on the straps and 3 teeth of the distribution were skipped then it went from lucky without damaging valves. If you have those manual my mail is thank you
12 years 6 months before #42113 by manual-mecanica
Friends I have not worked with that engine however I have worked with the Mitsubishi MF 98 and it is very similar to that, in the case that is the same engine, what is necessary there is to place all the pulleys in position and have the tool to adjust the tensor the tensioner xq the marks are roll, of course in the case that it is the same engines that speak
12 years 6 months before #42117 by manual-mecanica
12 years 6 months before #42116 by manual-mecanica
12 years 6 months before #42118 by manual-mecanica
Friends there I uploaded photos of the loss of oil from the seals, in this case of the crankshaft and the drip belts of Aciete.
