Hi everyone.
I'm getting desperate about my car because of two main problems. The first is a coolant leak that's been going on for at least a year. The garage replaced the radiator with a new one, but the problem persists. Then they told me to put a new cap on the coolant reservoir (I think it's called the expansion tank), but the problem continues, so I'm not trusting my "trusted" garage anymore. Regarding this issue, I've noticed some dark, greasy strands floating in the coolant in the expansion tank. For now, I'm fixing it by adding coolant, but I'd like to know if this problem could get worse (so I can start saving up in case I eventually have to take it to a garage). And I'd like to know the same thing regarding the second problem with my car: the radiator fan never turns on, even when the temperature reaches the "forbidden" level. Would it be enough to stop the vehicle (and let the engine cool down) each time this overheating occurs (to avoid a garage repair), or do I have to take it to a garage urgently for repairs? Could I fix it myself? Can anyone tell me how?
Greetings to all, and thank you in advance for your help.
