The fan does not enter
13 years 5 months before #34825 by manual-mecanica
Manual-Mecanica Answer on the Re: The fan does not enter
The PCM cotrola the relay by sending a negative signal of 12V when the temperature exceeds 98 degrees.
13 years 5 months before #34826 by manual-mecanica
You also have to check continuity after the PCM terminal to the revealing terminal in case you are not controlling the relay
13 years 5 months before #34887 by manual-mecanica
The departure is controlled by the vehicle computer, the best thing you can do is make a parallel installation, to solve your problem you do not damage anything and it works without any problem.
