VR6 MK3 Standard Jetta Problem
13 years 7 months before #33185 by manual-mecanica
Manual-Mecanica Answer on the Re: Problem with Jetta VR6 MK3 Standard
Indeed that switch only uses Ford !!!!!!
Check all the fuses
13 years 7 months before #33216 by manual-mecanica
Well that switch is of choke and is called an impact sensor and they have many modern vehicles only that Ford has it under the torpedo side copooto in the ranger but it varies according to models, this sensor only cuts the pump to the pump to avoid insertions in case of collision nothing more, if you do not have injection pulse, or signal in the pump or spark Atho says Czech all fuses.
13 years 7 months before - 13 years 7 months before #33278 by manual-mecanica
Ready friends, since I remain, I change the harness of the Camshaft sensor, that I fight to get it, I found it in a 2.0 that the transmission goes, I also change some cables that were damaged, I found a sensor in the carter that had the loose connector, I do not know if it is of oil level or if it is the crankshaft, but it is already
... aid...
Last edited: 13 years and 7 months ago by [author name missing ]. Reason: improvement
