Consult Almera 2003
13 years 7 months before #32867 by manual-mecanica
Manual-Mecanica Response on the Re: Consultation Almera 2003
That such a good afternoon because for what you comment, I could refer to could be your MAF sensor that is dirty, I do not know if you have already changed spark plugs or even to the obstructed air filter or even comes from the acceleration body that could have been deprogrammed I hope it is useful.
13 years 7 months before #32870 by manual-mecanica
If the levels, sensors in good condition are well and that are not disconnected or making false contact, the fuel is adequate and does not have impurities and the tb filters ... you can check the spark plug wires that do not derive to dough by rose wear or loss of isolation. Spark plugs, coils, and look in the portfusible portfusable and relay make good contact, check that all electric clemas are well connected or pink the cables .. Check everything that is a sensor, ... that is, everything that can send information to the switchboard. Because if the fault is erased, and then it appears it is because the malfunction continues to exist. This is what it occurs to me to look ... If I find out something else I will tell you! Greetings and I hope you can have the car repaired and working well!
13 years 7 months before #32884 by manual-mecanica
It smells like the coils that motor do you have?
