The same acite and water cordoba 1.9 d 1y
13 years 4 months before #31668 by manual-mecanica
The same acite and water cordoba 1.9 d 1y published by manual-mecanica
Hello everyone,
I have Seat Cordoba 1.9 D year 1998, the acite
and water, I think that the Board of Culate is evil.
Someone could explain to me, how to change
the butt together.
THANK YOU...
13 years 4 months before #31671 by manual-mecanica
Manual-Mecanica Response on the Re: The same acite and water cordoba 1.9 d 1y
hello. Before removing the cylinder cover, check the oil radiator (or heat exchanger) where the oil filter is lodged, as the engine coolant circulates there. It usually runs. It almost surely you have it there. Safe and luck friend ... Anything consult me ​​I am a mechanical technician and I can advise you.
13 years 4 months before #31672 by manual-mecanica
If the water is mixed in the motor carter, it is by the joint or chopped lid (1) .If the oil passes to the auxiliary deposit, radiator, etc. The problem is in the oil radiator (2).
13 years 4 months before #31676 by manual-mecanica
Hello Pampero
thanks for your answers is more successful than mine, the water expansion deposit
and the water radiator is full of a dark and sticky gray mixture.
So I'm doing your rabbit and looking at the oil radiator.
As soon as I verify it, I tell you.
THANK YOU...
13 years 4 months before #31714 by manual-mecanica
Hello,
I have already disassembled the oil radiator, there is some way of checking it.
I tell you that 5 years ago on a trip, Séme broke the water pump,
changed a mechanic and will now work well.
