Neon Chysler crankshaft pulley problems
13 years 8 months before #31508 by manual-mecanica
Hi friend
theseps have a sealant named Lock Time; And you must make it warm up and you have a new time you can get them.
The Time Lock is a high strength rubber so that the bolts do not loosen up
well
greetings
13 years 8 months before #31509 by manual-mecanica
Hello friend
these person have a sealant named Lock Time; And you must make it warm up and you have a new time you can get them.
well
greetings
13 years 8 months before #31630 by manual-mecanica
Greetings to all who with their contributions helped me solve the problems. The refran "The Eye of the Master, Egorda to the horse" says, because although I saw the mechanic of everything and not being able to take it out, I decided thanks to his contributions to take it out, I took a bit of everyone, I took a screw with a minor diameter, I made a center with the dril, so that the Pule had a center and did not move, then with the care that I did not lose its center, From now on it was very easy, I went out immediately, thanks once again. Greetings.
