Neon Chysler crankshaft pulley problems
13 years 6 months before #31497 by manual-mecanica
Neon Chysler crankshaft pulley problems published by Manual-Mecanica
Greetings Dear Friends, I turn to you again in search of your wise advice, I tell you, I set out in conjunction with the mechanic to make the change of time mail, and I find a serious problem, every screw that is used as support between the puller and the pulley is folded and it does not come out, I am desperate because I have the spare parts and I cannot change them. Someone has had this problem, as has been solved. Greetings and God bless you. Edwin
13 years 6 months before #31500 by manual-mecanica
Dear friend, the same thing happened to me, I broke a pulley extractor.
But then consulting with a colleague that happened to him the same thing I advise me to heat the pulley with autogenous (oxylene oxi) with the extractor put and start to tighten the screw as headquarters.
It is an arduous job to perspire as crazy thinking about that the pulley could be broken.
But apparently they come out like this.
Luck
13 years 6 months before #31502 by manual-mecanica
Thank you Dear Friend, for answering, I will take into account the contribution you make, thank you.
Edwin
13 years 6 months before #31504 by manual-mecanica
Good night cordaneous what you have is to put a screw of diameter that the damper wears the extractor that the same screw will stop the extractor and there is C is extracting the Damper taking into account that the Damper does not stop with the screw that utlisate commo bum
13 years 6 months before #31506 by manual-mecanica
Greetings friend, you know that I have thought as you aim, use a screw, if I find steel, with an at this way, so that the extractor or puller does not disregard, and tie the puller so that it does not open. In this way to extract and if not as recommended the previous friend, heat it and get it extracted. Thanks for your contribution. Greetings.
