Hi, I'm new. Traffic Diesel Problem
13 years 10 months before #31494 by manual-mecanica
Manual-Mecanica Answer on the Re: Hi, I am new. TRAFFIC DIESEL PROBLEM
Surely it refers to the rings of the pistons, your problem can be the so -called "vent" which lifts carter oil for not correctly closing the shirts with the pistons.
An easy test is with the hot engine running, remove the acite cap of the valve lid (where you made aceiter:) )
if it comes out a lot of smoke under pressure and light color is that it is burning you oil and that is the problem. Another is to measure compression as recommended.
Greetings and good luck with that.
13 years 10 months before #31507 by manual-mecanica
Hi Torino:
I thank you for the information. It is very useful.
Thanks a lot!!!
