Hi, I'm new. Traffic Diesel Problem
13 years 4 months before #31351 by manual-mecanica
Hello, I'm new. Diesel traffic problem published by Manual-Mecanica
Renault Traffic diesel:
I get a lot of oil to the admission multiple!
What would be the problem and the solution?
Thank you very much !!!
13 years 4 months before #31354 by manual-mecanica
Manual-Mecanica Answer on the Re: Hi, I am new. TRAFFIC DIESEL PROBLEM
I have little working with diesel and tube a similar problem and if the engine is turbo that can be the problem since that happened to me to replace the turbo
13 years 4 months before #31356 by manual-mecanica
Hello! Thanks for answering!
This model has no turbo.
Would you have any more facts? Please!!!
Thank you again !!!
13 years 4 months before #31359 by manual-mecanica
Of course, the colleague can be the turbo since it reaches oil pressure to the turbo to lubricate and possible or bad ring. Another cause the oil comes out through the hose of the valve cover and is connected to the admission, I suppose that the engine has a problem in the rings and the compression goes out to the carter and passes the cover. measure compression and if this bad repair engine
13 years 4 months before #31492 by manual-mecanica
Hello thanks for the data.
When do you say rings do you mean piston rings?
or the shirts of the shirts?
Excuse my ignorance !!!
