Electronic ignition Asia Towner.
13 years 9 months before #31117 by manual-mecanica
Manual-Mecanica response on the Reia Towner electronic ignition.
Hello friend..Tu problem could be the following ... your coil may not be working properly and it is heating passing a short operating period ... and when he is heated, he cuts the current circulation internally ... and that is why you have to wait for him to cool for a while and give without any problem the ignition ... Try another coil ... if you do not want to spend for pleasure, give someone a used resolved
That would be a fast solution..Avisans if your case is solved and if not there may be many other possible causes of your problem.
I hope I have been helpful with my humble comments ... greetings ... Jorge.
13 years 9 months before #31124 by manual-mecanica
To Kikemec and the apprentice23 thank you very much, in the end I decided to take it to a car electrician who recommended me. Anyway I appreciate the good vibes and the tips given.
Until any time.
Manuel
13 years 9 months before #31134 by manual-mecanica
From nothing Manuel, it would be good to tell us the results of the workshop so that other forists have an idea of ​​what it is, anyway if the module goes out it is not a guilty direct just like the coil, so the captor leaves us as the main culprit, and the sheet is where you put the key to that sheet I referred to luck and greetings.
