Mercedes Vito 110 CDI No Araca Saeft Error
13 years 9 months before #30844 by manual-mecanica
Manual-Mecanica Answer on the Re: Mercedes Vito 110 CDI No Araca Saeft Error
Well, thanks for the responses and tell you that Aveis ReaTau and took him to the Mercedes to pass the machine and an dochi that is pissed off the UFFF Motor switchboard fuck the paston that costs 1300 or less without VAT.
And my ideal is that if I could buy a cenagralite of scrapping of the but said in the workshop that if I buy a switchboard from another tedria firgoneta to also buy the switchboard of the car key you could tell me more omenos as I could solve it and that I needed thank you very much for the help.
13 years 9 months before #30852 by manual-mecanica
If it is possible to buy it in a disruption, you need the CR or switchboard, the WSP module and the key of the key, all of the same truck, since these three pieces are linked and has no problem, and logically it will cost you less, between approximately 50% less.
I recommend two things:
first that if you are going to buy in a disinchable disgust or that they try that it works in the truck that they are taking it away, in your truck or in any other.
Second: that checks that in your truck do not have any short since otherwise you could burn the new switchboard.
Good luck and you tell me
greetings
