cold ignition problems of a ranger 94 8b
13 years 9 months before #30797 by manual-mecanica
Manual-Mecanica Answer on the Re: Frio ignition problems of a Ranger 94 8b
It is cool and marks the same compression what I do not know is that if you should put a time of other talbes with casuaidad lamp you know something about it
13 years 9 months before #30801 by manual-mecanica
Hello friend, check the etc (Engine Temperature Sensor) (Motor water spin) The two cables is responsible. There are two guys, I don't know which one you have. Resistance with 20 grades c 2000 ohm and the other thinks is that of the Ford ~ ​​25000 ohm greetings
