HYUNDAY MECHANICAL BOX HELP
13 years 9 months before #30351 by manual-mecanica
Manual-Mecanica Answer on the Re: Help Mechanical Box Hyunday
Greetings, an album can be good, but when the paste's wear arrives at the rivets, it does not work, the same is sent to check the press tension, now if you already have more than 80K of kilometers and you have never touched the clutch, I think it is already asking for change. Another thing is to test the transmission on the floor and another mounted on the vehicle, remember that it does not have the load of the wheels that force the engine to accelerate, and therefore there must be a good coupling between the disc and the plate.
13 years 9 months before #30627 by manual-mecanica
Thank you friends, it for discarding to change the diaphragm coating to the disk and change the collar but nothing is the box today I will go down the box and I will still send it to it because of boxes do not know much or that say the disarm I
13 years 9 months before #30637 by manual-mecanica
If you do not know or do not have better knowledge, send it to a specialist I advise you
13 years 9 months before #30854 by manual-mecanica
Thanks for the help another sees my car as always
13 years 9 months before #30855 by manual-mecanica
I'm glad I greet desd Venezuela
