HYUNDAY MECHANICAL BOX HELP
13 years 9 months before #30198 by manual-mecanica
Hyunday Mechanical Box Help Published by Manual-Mecanica
I have a big problem, I was driving my hyundai and from one moment to another it began to skate accelerated but this did not advance for a period of more or less about 3 km then stopped turned on but does not walk the changes enter without tightening the clutch today Boy today to disarm
13 years 9 months before #30204 by manual-mecanica
Manual-Mecanica Answer on the Re: Help Mechanical Box Hyunday
Greetings Firefox, has the symptoms that the clutch disc came into its useful life, check whether the dish or steering wheel does not be ray or has furrows when disassembling, in most cases the clutch kit is changed (Disco and Collarin press), if it has furrows the dish will have to be rectified. Greetings.
13 years 9 months before #30206 by manual-mecanica
Good, you also have to check a vacuum system that activates the entrance axis of the box, if any hose is chopped or disconnected, I could change the clutch set a thousand times and will never work.
13 years 9 months before #30210 by manual-mecanica
It is a totally mechanical box and the clutch stop
13 years 9 months before #30212 by manual-mecanica
Greetings, by chance when it happened to you that the vehicle stopped Olia a lot of burned disk? If you already disassembled take advantage and take out the press and check the album and the plate, it must be clean as a new car disc brake. Another possibillity is some homocinetic detached but this failures once the vehicle does not go anymore.
