Astra 1.8 problem
13 years 11 months before #29785 by manual-mecanica
Astra 1.8 problem. Posted by manual-mecanica
Hi, how's it going? I have a problem with my 2001 Chevrolet Astra 1.8. I haven't had it long, but it's a pretty nice car, though it's not great. It starts fine and runs, but when I accelerate, instead of moving forward, it seems like it's being held back. I've already changed the ignition coil and oxygen sensors, and nothing has worked. It's been tuned up, and still nothing. What I've noticed is that it does it on inclines as soon as I start going uphill, and sometimes even on descents, as if it's braking on its own. Sometimes it doesn't do it, but there are times when I hit a bump, it fixes itself, but only for a little while. I hope someone can help me solve this little problem because I'm fed up with this beautiful Astra. Greetings.
13 years 11 months before #29792 by manual-mecanica
Manual-mechanics' response on the topic Re: Astra 1.8 problem
This issue is usually due to a worn clutch or a bad fuel pump; it could also be a valve adjustment problem. If it has hydraulic tappets, you can rule out that issue.
13 years 11 months before #29812 by manual-mecanica
Hey Kikemec, have the valves been adjusted yet? About 15 days after I bought the Astra, the timing belt broke and I replaced it. I also changed the fuel pump, but nothing has changed. Greetings
13 years 11 months before #29813 by manual-mecanica
By "clutch" you mean the accelerator pedal. Regards
13 years 11 months before #29844 by manual-mecanica
No, I'm referring to the clutch kit where the disc, bearing, and pressure plate are located.
