Astra 1.8 problem
13 years 10 months before #29785 by manual-mecanica
Astra 1.8 problem published by Manual-Mecanica
Hello, I have a problem with my Chevrolet Astra 1.8 2001 I have little with the but left bad and so beautiful car, it turns well and walking but when I accelerate instead of vanar I would stop it, they will stop it, I already changed the coil, oxygen sensors and nothing is refined and nothing remains the same way that I have noticed it is ke in climbs as soon as I enter it. Sometimes it does not do it but there are times when a pothole is composed but only a while I hope someone can help me solve this problem by what I already tire the beautiful astra greetings.
13 years 10 months before #29792 by manual-mecanica
Manual-Mecanica Response on the Rera 1.8 problem
In general, this issue is due to worn clutch or bad fuel pump, it can also be a valve calibration problem, if it is with hydraulic takies that theme discards it.
13 years 10 months before #29812 by manual-mecanica
What kikemec if the valves have already adjusted to the 15 days of Ke bought the astra, the time band is thrown and they were put new also changed the gasoline pump and nothing remains the same.
13 years 10 months before #29813 by manual-mecanica
To another thing of the clutch you mean the accelerator pedal greetings
13 years 10 months before #29844 by manual-mecanica
No, I mean the clutch kit where the dico is the bearing and the press.
