Fault
13 years 10 months before #29618 by manual-mecanica
Manual-Mecanica Response on the Re: Factory
Sioflaer wrote: Thank you for the answer.
I forgot to say that when I opened the hood in the car, it smelled of "Calentón", but at no time came to come out and the weirdest, I removed the plug of the water tank "very slowly because of the possible steam that could detach" and did not come out or steam or smoke, it seemed that everything was correct.
Is it possible that for a problem in the temperature sensor that message comes out in the instrument box, and that for that reason the engine is not starting?
Greetings
Hello, Merry Christmas. Let's see, I don't understand what you mean by "When opening the hood the car smelled of Calentón." The only smell "of Calentón" qeu distinguish is that of the varnish of the coils of the alternator or starter engine (electric motor or burned electronic compones) or the smell of burned oil. What smell did you refer to it.
Nor do I understand what you mean with "Remove the water tank cap and no steam or smoke." If smoke comes out of the cooling circuit, instead of steam, the thing has to be.
As the last colleague told you, first lift a wheel, put fifth and turn the wheel at hand to see if the engine is hard, but makes its compression movements etc. Or if on the contrary there is no way to move the wheel by hand (I would be gripped, bad matter).
Once you know that the engine is not gripped, when we understand more of the smells or that it is specifically what it does when trying (clack and does not move anymore, it does not make any noise, it turns but does not start ... explain and you will see how they give you more ideas, or the colleagues or me).
13 years 10 months before #29634 by manual-mecanica
Hello, thank you all for the answers.
I tell you. With the 5th march, the wheel rotates effortlessly and does not make any strange noise.
If I try to start, it does nothing anymore, it will be the battery that will have been exhausted, only the painting lights are turned on and off, but that I think it will already be a battery problem, tomorrow I will take him to the workshop to see what they tell me, I hope it is nothing serious.
Something has relieved me to know that with the 5th march the wheel is not blocked.
How do you see the issue, will it be face or normal fault?
Greetings for everyone
