Subaru Loyale Carburetor.
13 years 10 months before #29221 by manual-mecanica
Manual-Mecanica response on the Re: Subaru Loyale Carburetor.
According to the symptoms, the carburetor is covered, of some valve or some sple whether of gasoline or air, and if it has an air jalon, such as appears, anshopy explosions through the mouth of the carburetor. (or something similar as coughing) by ke when carburetor gasoline is needed by low level, fake false explosions.
13 years 10 months before #29249 by manual-mecanica
Check the PCV valve and the march of the car was normalized, but still gives some pull at the beginning.
13 years 10 months before #29302 by manual-mecanica
Compa If you put your hand and cover the entrance of Aiere of the carburetor must be left immediate
13 years 10 months before - 13 years 4 months before #29547 by manual-mecanica
Epilef wrote: Hello, I have a subaru Loyale 1.6 of 90 'and I need an exploded cable of my machine. It happens that I start and stop at the 2 seconds of what I turn on ... I put my hand on the carburetor and the car remains something better ... Buy the repair of the carburetor but do not change much ... it remains in idle but when accelerating it has a hard time lifting rpm ... If anyone knows what is the problem I have or what a solution there is please let me know ... Thank you very much.
Hello Epilef, I have found a very interesting article about the carburetor: www.desguacesvehiculos.es/mecanica/carburador-coche.html , in which he tells us what you can have and advice for better maintenance. I hope I have helped you.
All the best
Latest edition: 13 years 4 months before by .
13 years 10 months before #29549 by manual-mecanica
As the fuel pump goes, you want the detail.
