Sometimes nothing starts (help) (solved)
13 years 11 months before #28874 by manual-mecanica
Manual-Mecanica response on the Re: Sometimes nothing starts (help)
Ok thank you very much colleagues I'm going to check what they say, Salu2.
13 years 11 months before #28878 by manual-mecanica
You have two options:
1. rebuild the starter (in this case change the coals)
2. Buy a new starter
13 years 11 months before #28879 by manual-mecanica
This type of problem is presented by the agency anti -tree alarm. Check the following: With the "ON" key, check whether the dashboard lights work well and there is an orange that says "Theft" (it can also be a symbol) or something like that "if it is turned on is running normal and if you are blinking the car na will start if it is so the problem is in the key is very worn the resistance that carries the key and does not make contact well (the solution to use the other key that the other key is It does not work well is almost always the sheet of the sheet and can be fixed but I recommend that you visit some good electric to take off the alarm or the bridge or bypass
13 years 10 months before - 13 years 10 months before #29160 by manual-mecanica
That such partners, because with the novelty that the fault already found and it was the swicht who was failing, the solution was to put a resistance to simulate the key of the key (by pass), and ready no longer fails, thank you very much for the help they contributed, Salu2, thank you.
Latest edition: 13 years 10 months before by .
