distributor
14 years 2 weeks before #29031 by manual-mecanica
Manual-Mecanica Response on the Re: Distributor
Check the rotor and distributor. How can you tell if your wires are in good condition? How long ago did you replace them? What quality are they? Check the resistance of each wire with an ohmmeter. The reading should be the same for all of them. If one has a higher or lower resistance, replace it.
14 years 2 weeks before #29033 by manual-mecanica
Hey friend, check the distributor cap from the inside. See if it has the carbon brush in the center and if there are any spark gaps between the contacts and the brush. Also, check if the cap has any cracks. If the distributor has points, check the gap between the contacts; it should be 0.40
14 years 2 weeks before #29056 by manual-mecanica
Yes, they differ; the shorter one has less than the longer one. What is the margin of error for the cables? Does the coil's error count?
14 years 2 weeks before #29057 by manual-mecanica
The lid is like new, coal is fine and does not wear platinums, it is electronic. The cables would not know why I do not have a clear reference to try them
