Well, thanks again to everyone who was interested in my problem, and sorry for the delay in responding. I'm happy to report that I was able to fix my Optra, but the timing marks weren't aligned in any of the three ways you kindly suggested. The camshaft pulley marks were opposite each other, just as kikemec said, that is, the intake marks at 90 degrees and the exhaust marks at 270 degrees (clockwise), but the damper timing mark wasn't pointing up or down; it was at about 45 degrees. Once the marks were in place, I rotated the engine by hand (thanks kikemec for that tip
) until I completed a full cycle and noted which pistons were on the intake and exhaust strokes, which ones would ignite and which ones were exhausting, up to a firing order that, if I remember correctly, was 1-4-3-2 (I'm not entirely sure if this is the correct ratio). So I put everything back together using the torque specs pineda87 gave me (thanks for the tip, mate!), put in a new battery, and started it up. The strange thing is that for two days, when it got hot, the oil light would come on, but then it went away. I put in WD-40 semi-synthetic oil. The Hold light was also flashing, but that stopped too, although I don't know if the problem will come back because I don't think it's related to what I did. Thanks, guys!
