TEMPERATURE
13 years 8 months before #28550 by manual-mecanica
Temperature published by Manual-Mecanica
Good morning friends of the forum My name is Gustavo it is the first time I visit this forum and I would like to help me with the next problem I have a Toyota Tercel 3E 1989 Recent Hoverjoleado and I do not mark the temperature and turn on the oil light the oil pump the oil pump changed it about six months and the temperature bulb changed it when the hoverjol was made, when the temperature needle starts it, the temperature needle is made to the temperature. to the lowest limit so I do not realize when it really heats up .... I appreciate any help you can give me
13 years 8 months before #28553 by manual-mecanica
Manual-Mecanica Response on the Re: Temperature
Good morning friend.
Have you tried to use the car eliminating the thermostat?
This is the one that makes the water circulate through the engine, if it does not work well, it may block the water passage to the engine and it warms you.
Verify if the water lines do not stem too.
Greetings
13 years 8 months before #28562 by manual-mecanica
To the partner who answered the temperature, the problem is not heating because I cannot identify whether it heats or not since the temperature marker with the inition rises to the limit but when it starts it is returned to zero so it is not known if it heats because the score does not move today to buy the bulb for the second time and do not change the same thanks for your answer if you can help me with a new answer since I do not tell you that I do not He heats up since he does not mark ...
13 years 8 months before #28564 by manual-mecanica
Excuse me for not reading your problem well.
Let me investigate and see that we can arrive.
13 years 8 months before #28565 by manual-mecanica
Hello, your problem must be that the temperature cable is connected to the oil sensor and the oil light in the temperature.
Try to change them
