Problem: Hand brake indicator
13 years 11 months before #28444 by manual-mecanica
Problem: Hand brake indicator published by Manual-Mecanica
: Laugh: Good .. again I request your help in the following:
after the problems that my nuance 200 200 now flashes the brake indicator in hand, this depends on the vibration of the car (potholes) that turns on and off.
And in turn I listen to a small noise as if something Rosara does not know if it is due to the same.
The fact is that according to the mechanic you have to check the chicote ... my question is:
if you have to review that?
Can I do it?
How do I?
The truth tried to avoid my mechanic that lately every time I leave it and it gives it to me something is wrong and I had not given me any problem before my car.
Thanks for your help.
13 years 11 months before #28446 by manual-mecanica
Manual-Mecanica Response on the Re: Problem: Hand brake indicator
The indicator generally detects a low level of fluid in the brake fluid reservoir, and the noise you hear may be that brake pads are already low which makes the fluid level lower in the reservoir since the gag cylinders work more outside their seat, check the state of front pills and rear shoes and make the replacement if necessary.
13 years 11 months before #28453 by manual-mecanica
It has just over a month that both front and rear tiles were changed, the liquid is also level.
This error started after I changed my mace and ber from the rear tire.
There are occasions that the car is very forced to run as if it took the brake on.:(
13 years 11 months before #28522 by manual-mecanica
Greetings I ask you a question your car is 4 -wheel disc brakes or just use advanced discs and rear drums
13 years 11 months before #28535 by manual-mecanica
That vehicle if I remember correctly has traceras tales, I have the Cecaria the button that goes in the handbrake, to see if it is making bad contact sometimes get dirty or bridge, disarm where the clean brake goes and check the state of the connector if you want to leave the doubt leave that button operated, that is to say the signal with a little symptoms or whate This is the problem.
