The oil indicator light is turned on
13 years 11 months before #28279 by manual-mecanica
Manual-Mecanica Response On the Re: the oil indicator light is turned on
Good morning, the oil pump has a derivation valve to maintain the pressure, when the spring loses pressure this is a very common failure, the filters also have it. Eye there are other flags such as fuel dilution (viscosity) or the same oil.
13 years 11 months before #28284 by manual-mecanica
In general, if the light goes out when you accelerate is by oil precion and this can happen both by the pump and the oil filter, but beware that this failure also does when the metals are rotated
13 years 11 months before #28285 by manual-mecanica
hello! My first recommendation is not use! Until not solving the problem ,,,,,, everything that has recommended it seems possible as well as an oil change for another brand and perhaps another degree of viscocity ,, ready
13 years 11 months before #28289 by manual-mecanica
Thanks for the aid, my car is a 2005 Corsa, the oil is near the change, less than 150 km is missing. The matter with the oil is that I have always used semi -intentic oil and the last change were made in the workshop and I don't know what type of oil they placed it, so I have programmed the oil change for the next 5 thousand km .. I imagine that this oil will be the one that gives me the failure .......
13 years 11 months before #28290 by manual-mecanica
The first thing that should be done is to measure the oil precion,
in idle it should be in no less than 20PSI and in high there is even 40Psi, if these values ​​are inside then the fault is in the oil bulb (spring in Peru). If the values ​​are below there are internal motor problems such as pump or bench metals and connecting rod. These tests of course hot.
