Grand Nomade or Grand Vitara Difficulty in Encied
13 years 11 months before #28234 by manual-mecanica
I'm going to check it but I realized that when you turn on keeping the accelerator thorough
13 years 11 months before #28245 by manual-mecanica
Another of the probable causes is a covered catalytic converter, to determine this fault observes if it comes out gray smoke by the escape when you light cold and if at any time you hear any slight explosion by is escape.
13 years 11 months before #28266 by manual-mecanica
If you have the electrical diagram and the diagnosis connector you can make the connections you and scan the other is that you check the air flow sensor may be the problem or that the canister's purge solenoid is open
13 years 11 months before #28283 by manual-mecanica
Czech the temperature sensor is one of the main culprits and the second Czech the oxygen sensor, to be sure that is not the blame of a bad signal of fuel.
13 years 11 months before #28852 by manual-mecanica
Hello friends, they apologize so late but after a long investigation we determine that the problem of Grand Vitara was due to two specific sensors the first is the camshaft sensor that when heating he stops emitting signal and does not give a spark and the second is that it was in poor condition was the temperature sensor changed these two sensors the problem was solved.
