Sentra 2008 MR20 engine no longer turns on the engine
14 years 1 month before #27863 by manual-mecanica
Manual-mechanics' response on the topic Re: 2008 Sentra MR20 engine won't start
Cylinder 1 has 156 PSI of compression; in the others, the compression gauge needle does not rise
14 years 1 month before #27865 by manual-mecanica
That's strange, but it didn't suffer any choke or anything like that.
Did you try adding oil to all three cylinders? That should increase the compression.
It's odd that if you don't have compression, the valves are bent. That's happened to me when the vehicle suffers a slightly hard choke.
14 years 1 month before #27866 by manual-mecanica
No, it wasn't in any accident. I checked by pouring gasoline into the exhaust and intake ports when the engine was upside down, and I saw that gasoline was leaking out quickly through the valves. But at the machine shop, they told me that the valve seats and valves were somewhat pitted and weren't sealing properly
14 years 1 month before #27867 by manual-mecanica
Did you remove the cylinder head?
Does it have adjustable tappets or nuts?
14 years 1 month before #27868 by manual-mecanica
ADJUSTABLE COINS
