Sentra 2008 MR20 engine no longer turns on the engine
13 years 11 months before #27892 by manual-mecanica
I do not know if I get late but if you do not have compression in the 2,3 and 4 cylinders, it is usually the fault of a chain blow, it happens very little but it happens, this deteriorates the accounts of valve and these, if the valves do not seal there is no comprehensive is that easy, now the important thing would be to see why it happened so that it does not happen again.
13 years 11 months before #27896 by manual-mecanica
Hello, friend, it is never too late, thanks for answering the MSJ, NPO is indeed there is compression in the CIL, 2,3 and 4, now I already have the cylinder head that I send to the rectified, but I do not have the tightening of the screws of both the head and the bearing cover and of course the diagram of the set on time, if you would have the manual I would appreciate it very much, greetings friend and good day
13 years 11 months before #27921 by manual-mecanica
Kisierasaber if this celeage of the Xtrail will be equal to your feeling
13 years 11 months before #27922 by manual-mecanica
It serves you
13 years 11 months before #27926 by manual-mecanica
Hello, how this SR, a question once I turn off the vehicle I never turn on if it is so and tells me that I stop in the Super did not rob the control unit
