Sentra 2008 MR20 engine no longer turns on the engine
13 years 11 months before #27870 by manual-mecanica
They did the respective tests to the butt regulated the currencies
that rare the other would be that this poorly left the chain
you have the height of the distribution chain
is with a VVTI system?
The other would be that the VVTI is leaving the valves open and that causes no compression
13 years 11 months before #27871 by manual-mecanica
The truth does not know this system that you mention, so I would like if you have the manual, I would appreciate it with this, or tell me how to check it, because I do not have the squeeze of the cylinder head and less that of the cpojinet lid of the camshafts of the camshafts
13 years 11 months before #27872 by manual-mecanica
The truth does not know this system that you say, you do not have the manual of this model, or support me as the Czech, because I do not have the tightening of the cylinder head and less that of the bearing cover of the camshafts
13 years 11 months before #27873 by manual-mecanica
I do not have the handle but as I said it must be the same engine as the Xtrail but if you say that it is fine what is cylinder head, I think it is a problem in the chain is not well open or the VVTI system is being stuck, at this time I do not have the self -destroy of the self -destroy.
13 years 11 months before #27875 by manual-mecanica
Thanks for all my friend, a placcer know you and that you had bothered to talk to me, lucky good
