Nuance 2007 does not turn on
14 years 1 month before #26397 by manual-mecanica
Manual-Mecanica Response on the subject Re: Matiz 2007 does not turn on
Aaaaaaaah !!! Go ... a kind of "trrrrrrrrrrrrrrrrrrrrr ... is heard ... but you don't go, vdd ????, as if the battery were low, did you change battery ?? Did you check the march automatic ????? Etoances the problem is going through the march, they already tried to start pushing the car ??????
14 years 1 month before #26399 by manual-mecanica
I recharge the battery, and it does not go or spark only does the noise, and according to the mechanic the battery is not, I also check the time band and told me that it is fine.
At this time, he assures me about the immobilizer ... and not and tried to pushing it since the percase that the rear tire was thrown and the mace.
: Dry:
But I could try to push it and start it, since the key tells me that it goes above 2000:(
14 years 1 month before #26400 by manual-mecanica
Yes, the keys are expensive, but if it only does trrrrr ... is it that it does not go, as if the battery does not raise the march, the problem is that you have any problem in the march I suppose, you already fixed your Balero ??? Try to walk it by pushing it cousin ... I do not think you have a problem with the immobilizer, because if it were the immobilizer, it did not even make the trrrrrrr sound ... When an immobilizer does not work, what happens is that some cars "dirt" but never light, or flat does not go. but.
14 years 1 month before #26436 by manual-mecanica
I thank you for your help, I confirm in the end it turned out that if the key was broken, the chip was broken and they also unlocked the immobilizer apparently this was to take out the battery ... According to a bridge with another to avoid this error.: Dry:
What fails now is the handbrake indicator, turns on and off even if this position.: S
13 years 11 months before #27909 by manual-mecanica
Hello, I do not know if you already solved your problem, but as you mention, if only thunder and the march does not rotate, it could be the thrust solenoid of the march ("automatic"), it would be advisable to dismantle the march and try it with the battery outside the vehicle, to discard this component.
In case of being the computer, I understand there is a test by scanner called "ignition availability", you could either do it to check the module blocking.
