Nuance 2007 does not turn on
13 years 8 months before #26274 by manual-mecanica
Matiz 2007 does not light published by Manual-Mecanica
I hope someone can help me, I have a nuance 2007 a week ago I had a mishap on the highway since a rear tire was tied (the beal and the mace were thundered).
I gave it reverse to make it up and turn it off to verify, at 15 or 20 min that you try to move it to pray it but I no longer turn on.
When I turn the key all the indicators of the board light, if incist comes a time when it goes out as if battery is missing.
They already loaded the battery and nothing, scanned the computer and that does not mark anything, checked the spark plugs and does not mention the mecacino that passes gasoline that tested another bobiba and it is not the bobiba.
The fact is that they do not find that it is, and seen the forum there are in cases mentioned by the immobilizer or the deprogramming of the key.
I don't know what it can be.
I would appreciate your honest help.
13 years 8 months before #26300 by manual-mecanica
Manual-Mecanica Response on the subject Re: Matiz 2007 does not turn on
The starting engine tour? And yet nothing happens or the current is eaten and does not act it?
13 years 8 months before #26303 by manual-mecanica
13 years 8 months before #26313 by manual-mecanica
Hello, you will see the immobilizer LED when you give the contact at 5 seconds it goes out? If not, you will have to reprogram a key or verify with a sila spare you have
13 years 8 months before #26314 by manual-mecanica
Hey, do you have the owner manual ????? Check it and verify if you have automatic current for the fuel pump, because the Ford, when it has some percase, excessive vibration, or a strong blow, has a current cutter, and cancels the operation of the pump, probably this also has the system, they checked that the gasoline pump works ??????
